BuggsIslandlake
Thread starter- Joined
- May 15, 2006
- 19
I have a 1996 Wave runner with 80 hp. It is a 3 seater and has forward/reverse lever. When it is in forward you can move lever into reverse position while running. If you try to move lever back to forward it will not go. Shut the engine off and it will go back and forth from forward to reverse easily. Man at the dealership said an adjustment is needed on the cable but I can not find where an adjustment can be made. Also, talked to another person in the parts department of dealership and he said it was probably the bushings. I have a diagram of the exhaust/ forward/reverse mechanism but can't see which bushings would need replacing. Is there someone out there that would be familiar with this problem? Thanks very much.
