Have been chasing an overheat condition last couple trips to the lake. The overheat warning buzzer originally started activating at about 1/2 throttle. Eventually it began to activate at idle. Since then I have replaced the impeller and housing, the thermostat, and what I've read is a poppit valve or pressure control valve and my overheat condition continues. Tell tale seems to be pumping a good stream of water through. At this point I've run out of possible culprits.
Does anyone have any advice on what might be causing it to overheat?
