captain Gary
- Sep 9, 2009
- 5
My middle cylinder appears to not be receiving fuel. Outer plugs are wet and middle dry. Required full choke and fuel to start and continual throttle to run. It was very rough. After shutting off, I had a smoky vapor coming from outer cylinders and nothing from center after pulling plugs. Center plug was still dry and outer plugs wet. Should I check for compression by pressure checking cylinders? Any help would be appreciated.
