Justin Kennedy
- May 13, 2011
- 62
I've just finished repl. longblock on my motor. It runs great except for idle it surges between 800-1200 rpm. Once in gear, its fine. Also, I am unsure about the ignition timing because there does not appear to be any marks on the block. Could the timing be the cause of the idle surge? I have checked the vacuum lines, replaced the tps sensor, cleaned the throttle body, repl all gaskets, checked for air leaks in fuel lines(didn't find one yet)cleaned entire fuel system. filled w/ new gas. JK
