1996 Volvo DP-S tilt/trim sensor location
Status
Not open for further replies.
bcomer
I have the above outdrive on my boat anf the tilt/trim gauge displays the same thing regardless of the real position of the drive. Although I guess it could be the gauge my guess is that it is probably the sensor??<br /><br />Where is it located? What is the best way to test it? How many wires are connected to it?<br /><br />Any help would be appreciated<br /><br />Thanks
Don S
Re: 1996 Volvo DP-S tilt/trim sensor location
The sender is located on the starboard side of the gimbal ring. The arrow is pointing at it in this picture. <br />
<br /><br />Here is how you test and adjust it.<br />
cmyers_uk
I had the same problem on a Volvo Penta sx and from the diagram that Don posted it looks identical. What I found was that when I removed the sender (2 in Don's pics) there is a rubber nut shape that is turned as the drive raises / lowers in my case it wasnt tight enough on the shaft of the sender and as the drive raised it turned the nut but not the sender shaft. 2 drops of SuperGlue later and hey presto a working guage. <br /><br /><br />Regards<br /><br />Chris
bcomer
Thank you all. I will check it out next week when I go to the barn. <br /><br />Wierd though, I looked this over a million times and did not see any wires or anything that resembled a sensor of any kind.
mytthors
I have the same problem with my 96 Volvo Penta SX. Any chance you could resend the picture and test file? Thanks for the assistance.
Don S
Start a new thread with your question. It's not a good idea to ask a question at the end of someone elses thread. Especially a 4 year old one.
David Rauff
Why can't I access the photo and test information? The attachment symbols have a red X through them. Please help - this site is a life saver. Thanks
bruceb58
Because this post and the pictures are nearly 5 years old and the links point to an old location now.
gre9416
I am having problems with my trim gauge not working on my volvo penta. You posted something that had a diagram on where it is located at and how to test it. Can you repost the diagram because I can't not look at it. You help is greatly appreciated. bye the way it seems like you know alot about boats.
gre9416
Hi, I was wondering if you could send me the picture and how to test my trim gauge on my volvo penta. The trim gauge is not working. Can you send it to my email I am unable to up your diagram in this post.
bruceb58
This post was started 6 years ago
You should start a new thread.
Status
