vox populi
Thread starter- Joined
- Dec 11, 2024
- 9
1993 aries with a 96 venom, tach does not work, grey wire from dash to motor ohms good. replaced tach, still no signal, bought boat about 5 months back, tach has never worked, plug with 3 wires is plugged into motor and piggy backed to tachometer at dash from gray wire. tach has power when master switch is flipped on
2nd problem is very little reverse, prop is not locking in fully in reverse, i can take cable loose and hold the shifter in place , it will hold in gear, without me pushing on shifter it does not lock in. foot has been inspected, no wear on gears, shift shaft is at correct height is what iv been told., when shifting into reverse from neutral i go full back on shifter it clinks and barely will turn the prop. it goes into forward and runs great.
