1996 v4 90hp johnson on 16.6" larson flyer
tuckerman52
i just bought a excellent condition larson bowrider w 90hp johnson tach says bout 4900-- 5100rpm at some trim out and wot not sure what pitch prop on there will check tonite but is aluminum yesterday w 3 people she was turning bout 4800 rpm @ bout 37pmh... played with trim a little and all of a sudden she jumped to bout 41mph and 5200rpm like something let go in back,,,,my son said he read some where about a hull suction w this type boat in back where plug is at............its a 16.6" "flyer hull.. love this site..hope you can help... also looking at a evinrude 112 great condition...wondering how much diff that might make......the 90 also has a whale tail on it... thanks for help rm taylor...im told i should be at but 5400--5600rpm for good performance on that 90 lots of question but thanks not a first time owner but been a while thanks again for top speed PITCH???
emdsapmgr
You'll want to prop that engine or a 112 in the upper end of the factory recommended rpm range, or at 5500. That engine will still make good hp/torque to 5700, so a little over 5500 is ok. At 4900 or 5100, you are "lugging" the engine. Get a lower pitch prop. The 90 and 112 will each have about the same holeshot. Once up on plane the 112 will slowly pull away from the 90 and keep widening the difference. (The 112 will typically run a prop one pitch higher than the 90.)
tuckerman52
Hey man. Thanks info. Going to check pitch on prop boat came with. But you think I should go down on pitch? So if a 19 or 20 is on there maybe a 17 or 18?? And I waz told ss would be better and more effective? Thanks again. ...rob taylor
tuckerman52
Do you guys think I could put a 130 Johnson. 1998 model on this Larson. 16.6. Has 20" transom. So would need jack plate I think. Also ?? Top speed with 112hp. Evenrude. 2000 model. Comes with jack plate and control and fresh rebuild. Worth trading up from. 90 ua think. Would like to run. 42 to 47mph. Like I said. At one point yesterday. She jumped to 5100rpm. And bout 40mph. But only once. Wondering again like you said earlier... Maybe 2" or so prop change would do it. What about vertical positioning of 90hp. Up or down one notch. And waz told "whale tail". Should be even with bottom of transom when trimmed down...thanks again for help
tuckerman52
Reading your reply. Seems I'm definitely not getting the rpm I need. Sorry. I know you need to know current prop. Size. Will have that info tomorrow. Thanks again for help
