1996 suntracker party barge 21
xltjon
I need a fuel tank for 1996 suntracker party barge 21. It doesn't have one on it.
Most likely the tank was a portable. Look for portable tanks for your motot
aspeck
From what I have found, most of the Party Barges had a built in tank that was part of the motor pod. I believe they were anywhere from 23 - 40+ gallons. If yours doesn't have one, then you could probably pick up a used one some where, or more easily just use portable tanks.
xltjon
I would like to know what it looks like.
I was hoping to find the original tank, but thats becoming hard to do. Thanks for the info!!!
aspeck
I looked briefly and could not find an OEM tank for your Party Barge. I did not spend a lot of time on the hunt, so that is not to say there are none out there, but good luck in your search.
Chris1956
Gee, measure the area where you want the tank. An external fuel fill fitting may give you an idea where it was originally.
Now find a aftermarket tank that comes close to fitting.
Alternatively, there is a welder near me that makes custom stainless steel fuel tanks. I expect you will have one near you as well. Be prepared for sticker shock.
or call tracker. Tracker bought the tank from one of the tank suppliers
xltjon
Called tracker, cant help me. Ok thanks alot for the response, I found a 18 gallon plastic fuel tank that was previously on a pontoon. I think it will work. I was just trying to find out if anyone knew of a stock tank for it, but I'll figure it out. Thanks again!!!
