1996 Starcraft super fisherman 19. Needs carpet pleae help
appleo
Does the floor come up in sections? Any tips on recarpeting? I dread the thought of tearing boat apart
Appleo
appleo
Re: 1996 Starcraft super fisherman 19. Needs carpet pleae help
Nothing in archives I will try a post thanks
jbcurt00
The deck (floor) is probably riveted down
Carpet is likely OVER the plywood seams & rivets
It is also likely glued down
If there has been any previous work done on the boat, some or all of that ^^^ may be incorrect
You should read thru a few of the resto's Bob posted. Many of them are constructed similar to your Fisherman 19. Not exactly, but partly & similar enough to show what you likely face
Strictly speaking, you shouldn't need to pull the deck to replace the carpet. What's up? Got pix?
