1996 Reinell 196brxl prop size
mrwillcott
I purchased this boat just recently and the p.o. Had put a four bladed Michigan wheel prop on it. Vorrex 15x16. The hub kit is on wrong I think, the prop rattles on the shaft... I was thinking of replacing with a stainless prop, but wanted some size advice.
It has a penta 5.7gl and a cobra sx outdrive.
Starcraft5834
best to first determine that the prop shaft is not bent... spin the prop and keep your eye on the little milled hole in the center of the prop shaft, if it "wobbles" the shaft is bent. if not, it's not bent... likely missing a thrust washer or as you said hub failure...
