1996 omc 115 v-4 remove or not to remove oil injection????
lastdrift
Hi want to thank everyone for any information in advance. Would like any thoughts on removing or capping off my oil injection line and going to tank mixing. The system is working , but have heard all the horror stories true or untrue with these vro's . The motor has 350 hours pushing a 20 foot striper, last compression was 110 on all cycls. Any pros or cons greatly appreciated thanks .Jerry
Daviet
Re: 1996 omc 115 v-4 remove or not to remove oil injection????
You're gonna geta lot of answers on this one.
My personal opinon, I don't trust them. Having seen what happens when they fail. There are a lot of people who like them for the ease of not having to mix oil and gas. I would rather mix my oil and gas, no chance of running without lube.
anzomcik
I removed mine, and here is the reason. I have a 9.9 kicker next to the 115. The kicker is 2 stroke premix only, I wanted to run both motors from the same fuel tank. So I removed my VRO, and it has served me well.
If you are leery remove the VRO, because if your doubting it now and it works you are always going to think it will fail you. If your cool with it, leave it.
Each side has it benefits.
phillnjack2
Ensign
Vro is an engine killer.
omc and brp know it very well ,thats why they put the blanking plugs on the engines pipes ready to be utilised when you finnaly too k the oil side off and needed to plug it.
the navy engines dont have VRO, the rnli engines never came with the vro and the raf engines dont have it.
it was only done to starve the engines of oil trying to keep down emissions.
if you do manage to stay lucky, then good for you, but when it goes wrong at 5500rpm that alarm sound is way too late.
all the years that 2 strokes were on pre-mix noby had the amount of associated problems that these things give.
i would blank off the oil side, take apart the wire plugs use premix and enjoy a good few hundred more hours of happy engine times.
or start saving up for a new powerhead !!!!!
dont believe any of the hype about vro is good,it realy is not.
i dont see any advantage for it at all, you still have to put oil in the oil tank so its not like you never have to do this.
and for those who say its more conveniant, what about when having to clean the oil tank filters and buy new oil lines and bulb
and the oil filter under the engine cover ?
yeah you can just fill it up at the beggining of boat season and leave it in there all year to grab moisture and dirt and smash
up ya nice v4 pistons and destroy the bores.
VRO is only any good for marine parts shop and mechanics who have to rebuild your engine taking your hard
earned cash from your wallet.
go pre-mix and stay happy
phill
boobie
IMHO, I'd remove it and premix your fuel 50:1. They're fine when working but there's to many things that can go wrong with them.
Chris1956
Honorary Supreme Mariner
Gee, Phil just makes up the "facts" as he goes. In truth, everyone has just offered a personal opinion on the subject. Certainly motors can be ruined by the failure of the oil injection system. Of course they can have the exact same failure if the carbs clog up. No fuel = no lube.
In the end it is a personal decision to premix or not. The OMS system (4 wire oil injection pump) is a very good system.
If you decide to keep running the injection, I would you recommend you keep enough 2 cycle oil in the boat to premix if their is a failure or the OMS system.
Just so you know, I like the oil injection. It gives you a fresh mix at all times. It mixes at about 60::1 which is perfect for the motor.
lastdrift
Thanks for the early replies . Chris what would the ratio of pre mix to use in the tank with the vro still operating ? thanks Lastdrift
anzomcik
To cover your butt, mix the tank 50:1 even with VRO still in order.
If your thinking of removing the vro, premix your current tank you have in the boat. Run that tank through the motor with your VRO STILL HOOKED UP! This will ensure you have premix in your fuel line, carbs and sitting in your crank case.
If you just unhook the VRO then dump in oil in your gas tank you still got a fuel line, float bowl, crank case full of not mixed fuel, it may be enough to toast your motor.
A set of spark plugs are cheap compared to a set of pistons and an over bore.
