1996 Northstar Blast XL
embedded
I guess I am glutton for punishment. I have an older boat that I just bought that needs major work so I got a smaller boat - a 96 Northstar blast XL to take my boy out on the water. The hull seems to be in great shape but the motor has two issues - first, the fuel pump is shot. Second, the throttle cable is missing an end. And actually it is not missing - the guy I got it from was replacing the cable and dropped the end and it went under the gas tank.
The boat has a 115hp Johnson - I am assuming circa 1996. I do not want to keep the VRO system in it. I want to premix my fuel and gas and know for a fact that the engine will run safely. The engine will start if I put a fuel bottle on it with premixed gas - according to the seller.But with the pump, it will not start. I want to do away with that system but I am not sure what inline pump to get. Does anyone know an exact part number for an inline fuel pump I can order that will work well for this engine?
And before you say keep the VRO, my son works on ATVs for a living and the first words out of his mouth when I told him it had a VRO were - dump it.
Some pics here http://s1034.photobucket.com/user/kz1968/library/1996 boat
Thanks in advance!
Honorary Supreme Mariner
This set-up comes under Coast Guard rules for inboard installations.----that is why the VRO on this is likely inside a can....Be very careful if you start installing other fuel system components !!
