1996 Mercury XR6 150
bretmoua
If the floats in the carbs are not set properly, will they cause the rpm to be high...causing the motor to rev like it's in forward gear?
Re: 1996 Mercury XR6 150
Ayuh,... Mis-adjusted carbs will cause all sorts of issues...
Mis-adjusted floats could cause either a lean condition, or a flood condition....
What do the spark plugs say it's doin',..??
