1996 mercury 225 seapro (carb)
Fkoz
had water pump replaced in 2009 professionaly , put approx 300 hrs on in 2 years. now motor is peeing like a 70 year old.
could pump need replacing again ? want to replace pump myself. looked at some vidioes on youtube. looks like a somewhat simple job, is there a shift linkage that needs to be disconnected befor i can drop lower unit off to change water pump? or can i remove bolts and remove the unit ?
carholme
Re: 1996 mercury 225 seapro (carb)
What is your engine s/n and I'll get you the manual which you can download. Should be no shift rod disconnect.
Gerry
