1996 Mercury 225 EFI Offshore falls flat
TONY MAC
I have a 1996 Mercury 225 efi offshore that until recently was running flawlessly. The boat sat for about a year unused, tho I maintained a full fuel tank and ran it every couple of months. I topped off the tank with the 10% ethenol fuel and also put a container of the stabilizer made for the new gas. The motor was running fine the first time I took it out. However, now when I run it over 5000 rpms, it all of a sudden falls flat. If I pull back the throttle and punch it again, it will run for a minute then fall flat again. I have replaced all the fuel lines, both water/fuel seperators and found little debris if any. Initially i had a "cheap" primer ball that I noticed went flat when the engine died at full throttle, but replaced it with a "new better" primer ball and the motor still died, however the ball did not go flat. I tried to constantly pump the ball as I ran the boat at full throttle, but it still died, and the ball remained hard and full of fuel. If you have any suggestions for me I would greatly appreciate it. :confused:
Faztbullet
Re: 1996 Mercury 225 EFI Offshore falls flat
You need to check the fuel pressure to see it falls off when this happens, if so you have either a fuel pump,regulator failing or ECU driver failing. If fuel pressure is ok then it could be a TPS going bad. You also could have a filter on bottom of fuel pump in VST tank clogged do to varnish in tank.
