1996 Mercury 150hp 12 volt problem
ramjer
Started ok 2wks ago. Now no voltage to gauges,.power trim ,ignition . All other options work ok. Is there a fuse in harness that I am missing. Battery is fully charged. Help?
Dave1027
Re: 1996 Mercury 150hp 12 volt problem
Probably a bad connection. You will probably need a wiring schematic and a multi meter to trace it out. These are actually quite simple systems. Deductive reasoning and the before mentioned things and it should be very easy to find the problem. Maybe a cat or rodent chewed a wire?
