1996 Mariner 200 MAGEFI
TOTO1
An intermittent Beep Alarm is going all the time. The manual states oil injection system is the problem. The oil injection system has 2 sensors; one in the oil reservoir on the motor (2 wires Blue and Black) and one sensor on oil pump (3 wires; Black, Blue with white tracer and White) both sensors go to the Black Brain Box which has 7 wires; black, blue with white tracer, white, purple, blue, green, tan blue tracer)
How do I determine what the problem is? The engine seems to run ok with plenty of injection oil.
ImNu2Boats
Re: 1996 Mariner 200 MAGEFI
Test the float in the oil tank to make sure it's not stuck. You might also check the Temp sensor. I believe it ties into the same module at a terminal block on the engine. Check your manual.
TOTO1
I tested the float sensor with an ohm meter and it is working fine. The temperature sensor is connected to a different black brain box (module) and the manual reads that the alarm would be a steady beep if it were temperature related mine is an intermittent beep. HELP
