1996 Larson 176 Flyer Prop ?
flyer33
specs are 190 hp 4.3 gl
sx cobra out drive 1.97 ratio
current prop is Solas 14.5 X 19
WOT rating max of 4800
Ok so I just bought this boat, and at WOT it will turn 6,000 rpm. The prop has some small damage on it. looking to replace it. I dont need to go fast just need to not worry about the wife blowing the motor up by mistake. I have a WB tower on it, and will be pulling tubes, skies, and so on. could use some advise on how much prop would be to much. I'm thinking a 4 blade 21. But I have no experiance with 4 bladed props or this much motor. any help would be greatly appreciated thanks.
Re: 1996 Larson 176 Flyer Prop ?
Ayuh,... I'm thinkin' ya got the Wrong drive gear ratio, at 1.97:1...
With a Merc, that's a 4 cylinder ratio....
'n if yer turnin' 6 Grand, a 23" prop ain't gonna be enough to get the rpms down to where they gotta be...
steelespike
What is the speed at 6000?Is it by gps?
Is the leg labeled 1.97.Probably for a 3.0.It does appear you could get a 25" pitch prop for about 4800 rpm.
flyer33
WOW That realy sucks
Yes I got the drive ratio off of the lower unit tag. I'm not sure wat speed im running at WOT. I'm sure its turning way to many rpm's. I quess my next question is can I regear this housing or get a compleat out drive? Or try running a 25 pitch prop? Would putting a 25p prop on kill my low end? I realy dont need to go fast more of wakeboard speed is what i'm after.
