WarthogMan
Thread starter- Joined
- Mar 10, 2014
- 23
My 1996 Johnson 8 hp 2 stroke has tannish grey 'gunk' coming out of the exhaust below the cavitation plate. I pulled the lower unit and the 'gunk' was all over the cavity in the mid-section. I checked the impeller and it was in need of replacement. I also noticed that when it was running the water pump periodically seemed to quit pumping water and then exhaust would come out of the weep hole. I'm going to replace the impeller but I think the bigger problem is that water is mixing with the exhaust somewhere. Does this sound right? Should I change the head gasket or is there a more likely place where this might be happening? Any insight would be greatly appreciated.
