1996 Johnson 200 Venom
Bryant Davis
Looking at purchasing the above motor. Any known problems with this year model or make?<br /><br />Also, what is the difference bewteen the Venom, Intruder, Ocean Runner, etc?
Dhadley
Re: 1996 Johnson 200 Venom
The difference between the Venom. Ocean Runner and Ocean Pro is brand and styling. Theyre all 90 degree 3.0 liter closed deck finger ported loopers. The Intruder is a 60 degree looper.
glen357
Bryant,<br />They had some problem when they first came out. Had factory mods to correct them. Over size jets in bottom 2 carbs & retard timing 3*. Hope this helps. G
Bryant Davis
...so would the Venom be acceptable to run on a primarily salt water boat, or should I hold off for something else? What are the major differences in the Ocean Pro?<br /><br />Thanks for the help!<br />Bryant
EGallant
I have an Ocean Pro 200HP 1996. It has a serious problem with heat near the top cylinders. I need a rebuild due to broken ring. See my post below. ( Knock or Rattle Low Compression) Ed
Dhadley
The difference between the two is basically styling. Theres no reason to not run it in salt water. That basic 3 liter powerhead was the same from 1993 on. The 96 has the new style wiring. I think they are a pretty darn good motor. Just feed it fresh fuel, good oil, keep water out of the oil tank and use Champion plugs -- itll be fine. Dont lug it. The rev limiter is at 6200. Or 6700. See if you can hit it.
