1996 Johnson 150 Oceanrunner Overheat
David_GR
After running at idle and slow speed (no wake) for 20 minutes, the alarm went off and HOT light illuminated on the tachometer. It was a weedy area but water was still spraying out of the engine. i turned off the engine and it made a hissing noise. there were no weeds in or over the water inlakes. started again, alarmed sounded and HOT light still on. It's usually a pretty smokey engine (burning oil) but it didn't smoke that much, which made me wonder if oil was getting from resivoir into the engine (bulb was hard). I was towed into dock and now trying to decide how to proceed. i started it a day after, didn't sound right and still very little smoke. i didn't leave it running. advice?
ob
My advice would be to replace the water pump and inspect and or replace the thermostats. Then go from there.
cfauvel
Do you trailer the boat? when was the last time the boat was run?
as OB suggested, but to add to some causes that I have experienced
1 - ants made a home in my water pump area and when I started the boat in the yard ants and eggs clogged the thermostats
2 - wasp made a nest in the tell-tale (that didn't overheat per se)
Chris1956
Honorary Supreme Mariner
I would take a compression test. If your oil injection system failed, or the carbs clogged, the motor could overheat with a functioning cooling system.
A compression test will tell you if you have engine damage. You can then track down the cause.
cfauvel
Are you using the VRO with oil side still connected?
if so remove the oil pickup in the oil reservoir and inspect the filter sock and bottom of oil reservoir for a jelly like substance....the VRO's oil piston would have a hard time drawing up oil into it if the the pick up is clogged with this jelly stuff.
