Osprey 175
- Sep 3, 2003
- 4
I have a 1996 Johnson 90 VRO[removed!].. At WOT I am turning 4250 rpm. The motor should be @ 4500-5500,so it may be lugging a bit. Performance is not bad. My 1996 Aquasport Osprey 175 does about 33 mph@WOT and cruises nicely @28 mph. Another guy I know has the SAME rig and his tops out @ 35 mph,with a similar load on board. My boat has a thick, lumpy, crappy, bottom paint job,and 100 pounds of kicker and bracket[6 hp merc]on the transom. I feel this is the reason he is a tad faster on top end. My question is this. Should I replace the prop with one that will get me in the rpm range of 4500-5500@WOT? I am a few hundred rpm under spec[250] but will this effect peformance/fuel consumption enough to bother with? I was told my WOT rpm is far too low and should be close to the max[5500]@WOT. Will I get any increase in top speed or improvement in fuel mileage?. The boat is fairly heavy for 17 footer,well over 2200 lbs with kicker, gear, and fuel[not including 3 grown men]. Another guy told me his Osprey 175 would top out @42-43 mph with a 90 hp Yamaha. Sounds a bit optimistic to me!Anyway, just wondering if I will get a performance boost with the engine spinning faster than 4250. any thoughts???/ thanks for the help!!! bob
