Erik-The-Red
Thread starter- Joined
- May 2, 2007
- 21
This is my best friend's boat, a 1996 Glastron w/ a Force 90 outboard. The engine has run great since he bought it about 5 years ago. Just last year it started running a little rough so we pulled the carbs and cleaned/rebuilt all 3 of them, as well as the fuel pump. It has been running fantastic since then, used it all last season and already a few trips to the lake this season.
This afternoon, he was cruising out to our favorite beach on the lake and everything was running like normal. Out of nowhere, the engine lost power and wouldn't push the boat beyond 8-10 mph. If he stopped and put it in neutral, it would rev up to full throttle no problem. But then he'd put it in gear, as soon as the boat would start to plane, it would bog out and only crawl at 8-10 mph again. He had to drive the boat back to the dock at 8 mph which took almost an hour.
It kinda sounds like a fuel issue to me, but I can't understand why the engine would run fine while in neutral at all rpm's but won't run while in gear and under load. I mean, it runs, but it bogs out and has no power. This is an "all-of-a-sudden" issue, not something that has been persisting or slowly becoming worse with time. Any ideas as to where I should look? Thanks for any help or advice!
