1996 Force 50 HP Water Leak
bahama1
I have a 1996 Force 50hp that runs well. There is water coming from around the gasket(s) under the powerhead. I have checked the cylinders and there is no water present and the lower unit oil is not discolored by water. Can someone give me an idea as to which seals or gaskets to replace, and is it something that is a do it yourself repair? Thanks.
roscoe
Re: 1996 Force 50 HP Water Leak
It sounds like it is just the gasket between the powerhead and the midsection/exhaust leg.<br /><br />The lower unit is completely separate.<br /><br />Do it yourself? Sure, Pick up a repair manual from the Mercury dealer, disassemble, verify which gaskets are needed. Order them from Merc dealer, and install it/them.<br /><br />Or you can order what you need from www.mercurypartsexpress.com
tom kriz
Just wondering if anyone did this job. Service manual has you removing everything from Reed valves , starter, flywheel etc. Just wondering if all is necessary
tom
pnwboat
No it is not necessary. I've never done a 50HP, but I have done many 125HP and 120HP. You just have to disconnect the wiring harness from the engine, undo fuel line and remove the bolts/nuts that hold the motor to the lower leg.
tom kriz
Thanks for the information. It took me about 1 hour to get the power head off. Now I just need the gasket and reinstall the head. Thanks again
