Re: 1996 Force 120hp
Which cylinders are affected? If it is water, then it could be a bad head gasket, or bad exhaust cover gasket. Bad exhaust cover gasket usually affects the lower cylinders (#3 or #4 ). Leaking water from a bad exhaust cover gasket tends to run down to the lower cylinders. Neither is hard to replace, however, use caution when removing the bolts. Sometimes they get corroded and may snap off if you aren't careful. Head bolts need to be torqued in proper sequence to insure a leak free fix. You might want to do a compression check to see if you have any significant variations in pressure which may point you to a bad head gasket.
