1996 Evinrude OceanPro 200 compression
mcdanida
I got the following readings and would like specs or feedback if I'm OK with compression: STBD - 115 psi top, 115 psi mid, 108 psi lower ...PORT - 114 psi top, 105 psi mid, 100 psi lower. Seems OK to me but want an expert's opinion.
jakedaawg
Out of spec. Will run but not well. Depending on what you want out of the motor it's time to inspect further.
mcdanida
Do you know what readings I should get? I have it on a 21' Center Console, once it planes, running 4000 rpm, full throttle 4500-5000 depending, and gets speed of 35mph, it runs smooth, sounds good. I do have it conk out on idle a lot, and lower to me a little noisy, but it runs OK. Powerhead was remanufactured in 2005, mostly salt water. Am I reaching the end of its life maybe?
Chris1956
That 100PSI reading is just a bit out of spec. However, I think it will be fine. Sounds like it needs clean carbs and a link and synch.
mcdanida
I imagine adding carburetor cleaner to the fuel could help, but what's a "link and synch"?
1983 ercoa 21'
You can always try a decarb treatment. Search it here you will find alot of links about it
Chris1956
Mc. Outboard motors need the timing synched to the opening of the carb. They also need max timing set.
I would think you can find a link-and-synch posting in the top secret thread.
G
Guest
Guest
I have a 98 Ocean Pro and the Link and Sync procedure can be performed yourself, but I strongly recommend you buy an OMC shop manual for that motor to do it. It takes you step by step through the procedure. (If its running now as good as you describe, you may not even need to do it) Fortunately, if you're not confident enough to do this, any Evinrude and or Johnson tech will know how.
But before you do that, run a couple of cans of Sea Foam when the fuel tank level is low, and that should certainly clean out your carbs and remove any carbon or coking on your pistons. My Ocean Pro responded well to this. Run the engine normally for about 20 minutes then shut it down. Let the Sea Foam soften the carb deposits and crud in your low speed (idling) jets. Then start her back up. She may smoke like crazy, but you're just burning off the loosened carbon and crud in the cylinders and carb jets. Its an easy thing to to do before tearing into the linkages.
These particular engines have to be de-carbinized at least once a year
You can use Sea Foam or BRP Engine Tuner. There is also a Schrader valve on your engine to ingest the Engine Tuner directly into your engine when running.
As for your compression, its fine. The general rule of thumb is that when all 6 cans are pulling within 80% compression of each other, your powerhead is fine. This is even stated in the OMC shop Manual I have.
You also seem to be propped with a little to much pitch, that motor should be turning 5500 -5700 rpm at WOT.
mcdanida
Thanks CaptErich. I will certainly do that. Yes, I have a higher pitch prop. I run 35 mph full throttle when planed out with family of 4 On boat. Reading around 5000. It sounds good also. I'll do the preventative stuff, seafoam, etc. Gonna let her run for now.
