1996 Evinrude 28 hp SPL engine fire in high idle, then kills
llmoos@cs.com
[FONT=&quot]I have a 1996 Evinrude 28 hp SPL engine that was running fine, but lost power and stalled on the lake. I could get it to fire on high idle for a few seconds but it then kills. I changed the gas, added Seafoam with no improvement. I could keep it running by "fluttering" the choke on the carb to keep it running longer, but it would eventually kill when the high idle lever was lowered. I suspect a clogged carb since it does fire up initially. I'm a novice with outboards and a little reluctant to start pulling parts without being sure of what I need to fix. If it is the carb, is there an easy way to get at the jets without pulling the whole carb (and the starter to get at it)? Thanks for any help you can give me.[/FONT]
oldboat1
might check and clear the fuel pump screen first -- simple stuff. sounds offhand like it could be fuel supply (fuel pump or carb) -- either one has to come off for proper fix. Can ask a shop what the cost is for carb cleaning/rebuild, or fuel pump repair. Do some searches on carb or fuel pump rebuilding, and ignition diagnostics for your CD system. Depends on your cash position, skills, interest.... hard to say from here. Good to check parts blow ups and see if it's something you want to take on.
Honorary Supreme Mariner
How long have you owned it ??-----------Was waterpump impeller replaced.------------Have you checked compression ?--------Have you tested for strong spark ??---------Have you checked for water in the fuel ??-------Have you inspected fuel line , including the pick-up tube in the tank ?
llmoos@cs.com
Thanks for the responses - I appreciate the help;.I have had the engine for six years - no prior problems. I checked the fuel filter screen - no accumulation. Same with the tank pick up - all clear. I can get the engine to run at high idle just fine for at least a minute or two until I try to idle down to the normal idle with the main jets. Plugs look fine, with a little dry soot covering, but I will replace them just for insurance. The fact that it runs strong with the idle lever up makes me think that it's not compression or electrical, but I certainly could be wrong and missing how they interwork.. I did change out the gas and added Seafoam with no results. I think I can take on the carb rebuild once I figure out how to get the starter bracket out of the way. Any other thoughts? Thanks again.
oldboat1
be a good idea to look at some youTubes on carb rebuilding -- maybe one out there on your engine. (Google is your friend...) Have an idle speed needle, but adjustments are sensitive (if the carb is clean). Take a look at a parts blow up of the carb, starter, etc. to get a sense of how it goes together. Think you really need a manual, if you don't have one.
Tim Frank
[FONT=&quot] I'm a novice with outboards and a little reluctant to start pulling parts without being sure of what I need to fix. If it is the carb, is there an easy way to get at the jets without pulling the whole carb (and the starter to get at it)? Thanks for any help you can give me.[/FONT]
You would be doing yourself a favour by buying an OEM manual.
It would pay for itself in short order.
