1996 evinrude 25 hp oil leak
futsal
I bought a boat with a 1996 evinrude 3 cyl 25 hp 2 stroke and it leaks quite a bit of oil out of the reservoir is there anything I can do to fix or should I just get rid of the system and mix it myself
Honorary Supreme Mariner
That mixing unit and oil tank should have been thrown out years ago !!-----Do a compression test, post the numbers here.-----Install a new water pump impeller now.
