Re: 1996 Evinrude 150 Running off rinse out OK?
Way, The owners manual of my '98 Johnny 150 V6 says that "the flush port on the rear of the motor may be used with a hose to flush the motor running or not, tilted or not".
I normally use the flush port to flush the motor when the boat is in the saltwater. I start it and run it a while with the hose connected and water on, and then I tilt the motor up and kill the ignition as it tilts, but let the hose run until the leg is out of the water.
Now on land, the hose in the flush port works OK as as well.
