1996 Evinrude 150 Intruder top end revs
bruteforce
Being a new outboard owner I have a few questions. I recently purchased a 1996 Evinrude Intruder 150 V6. It had a piston slap on the one cylinder so I had that cylinder re-bored, sleeved, and the relevant replacement parts installed.
On starting up, the engine idles and revs like a dream... now for my problems.
The throttle linkages and gearing I can't get right. If its set up for forward, I cant get reverse, if I get reverse right, I cant get forward. Any suggestions?
On the water I settled for forward gear to see how the engine runs. If I throttle up quickly, it cuts out. If I throttle up slowly I can get up to speed. It does however not get up to full speed or revs, only about 3/4 (as though it has a governor on it) It also gets a continuous beeping engine alarm but it still runs at normal running temperatures.
Could the problem be the throttle problem or are there other factors I can look at? I would appreciate any advice or checklist I could go through. Thanks in advance. Brendan
tashasdaddy
Re: 1996 Evinrude 150 Intruder top end revs
stretched cables, mis adjusted shift shaft height. the rest sounds, like either contaminated carbs, fuel restriction, or link and sinc problem.
is the Oil Mixing pump still operable? which beep?
J/E Alarms
low oil alarm is a beep every 30 seconds. beep......................beep...................
no oil alarm is a beep every 1/2 second or so.beep,beep,beep
overheat alarm is a constant beep.beeeeeeeeeeeeeeeeeeeeeep
