1996 Evinrude 150 fuel question?
pkp445
When i pump up my bulb it pressures up and I have noticed a gas smell so I started searching and found that when i pump my bulb gas squirts out of the vapor separator resevoir. The gasket looks fine would the float cause this to happen, or is it something else maybe the primer? Any help would be appreciated.
dish
Re: 1996 Evinrude 150 fuel question?
What part of the vapour seperator?If its around the seal then you have your answer.I used gasget sealer on mine,sealed it perfect.
Chris1956
Honorary Supreme Mariner
The vapor seperator has a float, inlet needle and seat, like a carb. They could be bad.
