1996 E60TLEDR, 60 HP evinrude ignition question
rowerowe101
my old ignition siwtch/solenoid broke off, shop i bought new one from "promised" replacement solenoid/key is the right setup even though it says made for 1977-1995 evinrude (mines a 96). However, it looks the same as the old one that broke off so hopefully theyre right.. If it does manage to work, is there possibility of damage to the ignition system if it isnt the actual correct ignition switch?
Daviet
You need to use the correct ignition switch for the system on your engine. What do you mean by switch/solenoid?
