1996 90 horse merc
1996 95xr no spark issue ,disconnected weather and ignition switch still nothing,most likely the stator? Any help or suggestion would be helpful thanks
Guessing gets expensive.----Do some tests on stator and trigger.----Also charge battery / load test battery and take starter apart for cleaning and ohm test.
QBhoy
Hi. I’d check the lanyard/kill chord circuit
Already been mentioned, what to check if not
