1996 75hp Force head torque spec
ctriver
Can someone tell me what the head torque spec is for a 1996 75hp Force. Also is there a re-torque after the engine warms up.
PaulO
Re: 1996 75hp Force head torque spec
1996 S/N 138600 - on 75, 90 ans 120 hp use new torque procedure. Lightly oil threads and underside of he head of each bolt. Torque in sequence to 120 in-lbs then turn each head bolt in sequence an addittional 90?.
Reference (Clymers Manual)
shytownborn
if a new head gasket re torque, if used no
ctriver
Thank you very much for the help.
jason32038
On my 85hp force the torque specs were 22.5nm or 12.5 ft lbs if i remember correctly. This spec has always seemed way too low for me to trust and i've always done mine gently at 30 ft lbs with new grade 8 bolts that is.
