1996 75hp:decarbonizing works!
tatertot
Original owner, no problem what so ever until this year. First time out this year ran great for 15 min., then completely died out, stopped dead.<br />Temp. alarm was going off, would restart, ran very rough. Started off replacing water pump, was circulating water but wouldn't keep running. I then rebuilt fuel pump and it ran smoother but not quite up to snuff. <br />I then decided to check compression: #1 cylinder ran 30, other two read 130. Found my problem! Hoping for the best, decided to decarb as mentioned on this site. #1 cylinder came up to 120, other two remained at 130.<br />I want to thank everyone who contributes to this forum. Wouldn't have know where to start w/o it.
roscoe
Re: 1996 75hp:decarbonizing works!
That is a remarkable come back on the compression tatertot.<br />Glad it worked for you.<br />You probably had a stuck piston ring.<br />You are lucky you unstuck it before it broke and tore up the head or cylinder wall.<br /><br />Good job.<br />Make sure you do it once a year to keep it running well.<br /><br />Happy boating.
tatertot
Thanks Roscoe. Should I decarb my Yamaha 9.9 <br />4-stroke also? It is 4 yrs. old and running great. Is it done the same way as my Force?
roscoe
9.9 likely won't benefit much, if at all, being a 4 stroke.<br /><br />I would just put some Seafoam in the gas and let it clean out the fuel system.
