Re: 1996 5.7l EFI with Bravo 1 overheating immediately.
Hardin wanted $25 each for them. Did you use theirs or source them somewhere else?
Yeah,
I didn't think I'd want to buy theirs either. I just used a couple of brass hose-bibs and a 90 degree brass pipe "ELL" & nipple from McClendon hardware. those are 1" NPT fittings......... even brass is pretty expensive.
There is a problem with standard brass fittings though. They BARELY fit even after I cut and re-threaded the fittings a bit. the fit is VERY tight with the engine mounts. (I don't know how much room you have there with the 5.7l engine)
I also thought about using PVC. They're pretty rugged and probably would be adequate.........I might worry about them breaking though.....
The Hardin Marine elbow might be the best choice because it's a rather "close-in" "ELL" and shouldn't even come close to the engine mount.
Also, if you have a hose that runs under the engine (you have cool fuel?) from the pump discharge (like my 454) , consider putting a plastic TEE in the line that is at the lowest point of the hose.
I got a heavy plastic TEE with hose bibs on each end and a (1.5" pipe) threaded middle so I could put a plastic plug in it to easily remove. That way you can unscrew the plug and drain any water that might be in the hose at the lowest point.
I even considered putting a plastic (PVC) ball valve at the TEE (instead of a plug) so I could reach in and open the valve for draining, but the plug works well if you just put some (2-4-C etc) grease on the threads and don't tighten it too tight.
