Re: 1996 4.3 Chevy/Volvo Engine proplems
When you do a compression test, make sure the throttle is wide open to allow air into the cylinders to get a true reading. First test do it dry no oil or anything in the cylinders. The second time squirt some oil in the cylinders and redo the test. If your low cylinder pressure comes up it could be the rings, if it doesn't it could be the valves, head gasket, etc.
