1996 3.0 LX Mercruiser Alpha One won't start
victorc1
I was zooming along and hit a wave and the motor shut off. I started it again and took off but it shut off again. Anyway, before I went out I forgot to charge the battery and to make a long story short I had to be towed in.
Now on land and at home I charged the battery and tried to start it and it doesn't start. Its getting gas in the carburator and the spark plugs are sparking. I checked each one individually. I also poured gas directly in the carb and nothing. I checked the compression in the cylinders and its good, also there is no water in the oil. Need help please.
Don S
Re: 1996 3.0 LX Mercruiser Alpha One won't start
Disconnect the coil wire from the distributor cap and hold it about 1/2" from a good clean ground and crank the engine. You should have bright blue spark. DO YOU?
futz
Banned
kill switch half in??????
victorc1
There is a blue spark coming from the coil and the spark plugs are sparking and its not flooded, tell me more about the kill switch
futz
Banned
you have a string attached to a kill switch, make sure it's all the way in the plastick wedge.
victorc1
where exactly is the killswitch?
futz
Banned
maybe next to the keyswitch. You don't have any string hanging off a switch on the dash maybe next to the throttle.
victorc1
Do not have any of the 2.
futz
Banned
do you know what every switch every knob on your dash does?
Don S
IF the kill switch was bad, you wouldn't have spark. All it does is kills power to the coil. No power to the coil, no spark.
Fun Times
When you turn the key on do you have power at the dash looking at your gauges? And have you checked fuses at the dash and back at the engine area?
victorc1
Like Don said "IF the kill switch was bad, you wouldn't have spark. All it does is kills power to the coil. No power to the coil, no spark. I'm going to get up early today and check again, first I'm going to check the timing. If I find the problem I'll post it.
victorc1
Okay so I checked about almost everything and there are 2 spark plugs that are bad, they don't spark. For this motor 3.0 LX, do they have to be marine spark plugs or can I use automotive plugs and I also checked the gas filter which I changed last month and in the bottom there was water and some other stuff that looked like sludge.
