Make sure that the spark advance timing plate under the flywheel is moving all the way to the rubber stop when you throttle up. You can do this without the engine running. It should move freely and not stick. Also, when it starts to die have someone squeeze the primer bulb several times and see if it picks up. If it does, then just replace your fuel pump.
