1996 200hp Yamaha Saltwater Series, rough idle
ddzurik
One of my twin 200's is idling rough and also seems its not revving up like normal.
Any hints at checking for simple electrical problem like a bad coil or a plugged idle
jet on a carb. thanks for any insights.
Dave
99yam40
Re: 1996 200hp Yamaha Saltwater Series, rough idle
check compression on all cylinders, spark on all cylinders with a spark tester set to 7/16", and timing with timing light.
If all that is good the look at fuel related problems. Pumps and carbs
