1996 200 johnson venom
Keith1978
I have a 1996 200 Johnson venom have replaced timerbase,stator,powerpack,new fuel pump,rebuilt carbs and changed reed valve. Compression is 100-105 on all cylinders. My problem is motor will run good and all of a sudden it will run bad missing no power. My mechanic has found that it is something to do with number 6 but is at a loss if you can help thanks
Captain Jeff
Did you take a look at the spark plugs? Is number 6 wet? You could be getting intermittent spark on that cylinder. Could be the coil pack. You can use a spark gap tester and see if you have a good spark when the issue happens.
Keith1978
Thank you yes the plug is wet I will put the tester in and check it coil shows to be good with meter
