1996 150hp Evinrude problem
kit48
Hi
I have a 1996 150hp when I put maximum speed it not work smoothly and if fuel tank is low not work smoothly low or maximum speed ( like Fuel is not up to the engine properly )
any help I would appreciate thanks
OutOfControl
Re: 1996 150hp Evinrude problem
kit48,
Try a few simple things and go from there.
I assume that the motor will run at idle or low speed if so try pumping the fuel bulb when accelerating.
Change any filters if you haven't already including the one mounted on the fuel bracket at the front of your motor.
Check hoses, fittings, and clamps for leaks.
Let us know what you find.
boobie
You may want try hooking up a 6 gal tank directly to the mtr and try that. This by passes the boats fuel system.
