russell lemaire
Thread starter- Joined
- Jan 29, 2015
- 2
1996, 150hp ocean pro. i bought the boat three years ago and took it to a local mechanic with instructions to go through the whole boat and repair anything that needed to be. he changed the fuel pump, fuel guage, new plugs, new thermostats, new water pump in lower unit, new power pack. boat ran fine for the whole year. now, when i put the boat in the water, i pump the bulb tightly, choke it, and it will will fire right up, and stay idled up high only for 2 seconds, then idle itself down to a normal idle, then die. it seems to me that the motor does not realize that it has not warmed up yet. it will do this 5 or 6 times, each time, it will run a little longer before stalling out. finally, it will stay idled long enough to stay running, rough at first, then smoothes out. this is putting serious strain on my battery. not to mention the embarrasment at the launch with other people waiting for thier turn. once it will stay idled, it runs and accelerates fine. after i get to my fishing spot and slow down to an idle, it dies again. after fishing for only 10 minutes, i have to go through the same routine to start it again, starts, then dies. 4 or 5 times. when i get ready to trailer it, its a constant struggle to keep it running at low rpm to even get it back on the trailer. i would appreciate any help i can get. thanks.
