1996 150 fast strike keeps flooding
bar_b_cue2002
Maybe a rookie mistake, but I have a problem with my 1996 150 fast strike. I've had it run for a few minutes but it runs really rich then it dies out. When I pulled the cover off I found the bottom of the air silencer full of gas/oil mix. I was told when I got the motor that I needed to raise the lever and to push the key in when I start the motor. Starting it with the silencer off brings fuel spitting/gushing out of all six carbs. The red lever on the primer solenoid is in the down position and the plugs are all soaked. There doesn't seem to be a problem with spark at least outside of the cylinder. and the battery has just been charged and turns the motor easily. Has anyone seen this before?
Chris1956
Honorary Supreme Mariner
You need to identify where the extra fuel is coming from. Two likely sources are flooding carbs and malfunctioning primer. Remove the airbox, and put a flusher on the motor. Run the motor at idle and see where the fuel comes from. If it comes out the carb throats, the floats/inlet needles are malfunctioning.
You are sure the primer knob is in the run position? Pull the primer hose off and see if fuel pours out, with the primer in the run position. If so, it is malfunctioning.
If it comes from the rubber hoses that go to the vapor pump, that item may need to be rebuilt or the vapor separator is leaking.
