1996 150 carb ??askets and o-ri
gw204cc
I recently purchased this motor and finally it was warm outside so we fired her up. I need to order some gaskets and o-ring due to leaking fuel.My question is does the butterfly shaft have any o-rings.There was gas dripping from them or the carb gasket in the back.It wasn't much but any leak is to much.This motor was stored for several years so the gaskets and o-rings dried up I guess
emdsapmgr
You can view the factory exploded parts diagrams for your exact engine at the factory website: epc.brp.com. Bombardier sells carb kits for each carb (sold separately) 438996 The carbs on this engine are plastic-check them to be sure their components are not warped. This is a more complex fuel system than the old crossflow engines- what with a vapor separator and all. You may want to work from a factory service manual
