1996 130hp johnson
southtexas1960
The VRO was deleted years ago on my motor and now the fuel pump has failed, thinking of replacing with electric pump, anyone every done this?
boobie
Don't try an electric fuel pump as they are a FIRE HAZARD ! Repair or replace what is on there now.
Silvertip
Honorary Supreme Mariner
I do not see why folks think an electric pump is the solution to a failed mechanical pump. They fail to realize that should a carb problem occur and the engine dies, the pump keeps running filling the engine with fuel. Attempts to restart the engine results in a bang (a big one at that). Use of an electric pump requires an automatic shut-off should the engine die. This is why an oil pressure switch or the ECU on modern engines controls the pump. And NO -- you will not remember to kill the pump with the ignition switch in an emergency. You have been warned -- DON'T DO IT!
