1996 120 force..coolingtell tale stream
storkrd4
at idle, no water from outlet, but flow at higher rpm's... replaced pump...same proble, then I noticed that motor has a thermostat(my 40 merc. does not... i dont think)...does motor have to warm up to show a stream???? we have not put boat in water yet... only run motor about 30 to 60 seconds each time with flushing ears
lonewolf5347
Re: 1996 120 force..coolingtell tale stream
JIM:I HAVE A 120 HP 1994,WHEN RUNNING WITH EARS ON AND TROTTLE IS SET TO ABOUT 1000 RPM.WATER START TO FLOW IN ABOUT 20 SEC. FROM START UP.
