1996 112 Evinrude - sounds like only 2 cylinders
seadog411
Guys -
My boat has been in and out of the shop all summer. I have had only one day of successful boating....
Had boat out two weeks ago and ran GREAT!! Just got out of the shop for a cracked cylinder head - painful.
Went to start late this afternoon. Started, but never idled well. Sounded almost as if it were running on two cylinders. Would run for 10-12 seconds and die.
I changed the spark plugs - now boat won't start at all.
Any ideas??
Thanks!
Monte1961
Re: 1996 112 Evinrude - sounds like only 2 cylinders
are the plug wires in right location?
seadog411
Yes - I just double checked. Thank you for your reply any others thoughts...?
Monte1961
I know you must be frustrated at this point with motor, but i do have a few questions I would like to ask. While in the shop, what all was done. Can you post this back? I don't want to take you on a wild goose chase. Post back.
seadog411
Could be a goose chase.... Cylinder head was pulled, welded and replaced. Carbuerator was cleaned - both high and low speed jets. That was really all - money is short these days.
thanks!
Monte1961
First? why was the head welded? Ok while squeezing primer bulb, will it stay running? Get a spark tester and check if spark is hot and has a snap sound? post back
dradford78
Did they set the idle adjustment correctly at the shop?
seadog411
That, they said, was the repair needed... I will have to get a spark tester tomorrow am. and post back. Thanks again...!
seadog411
They must have since it ran perfectly two weekends ago. When it did start today, idle was very week...
emdsapmgr
Put an inductive timing light on each of the 4 plugwires. The flashes from the gun will tell you a lot about the quality of spark. No spark, intermittent, weak, etc.
