1995 tracker pro 18 motor lift
Chris400
I have a 1995 tracker pro 18 the motor lyft will not work some of the time no matter which buttons I push at any station sometimes it will work what could be the issue causing this I can hear the relays clicking like it should work but nothing happens and then sometimes it will work fine Both relays have been replaced in the past
dwco5051
You did not say which motor but every couple of years my 1990 Johnson on my Tracker Nitro would start acting the that way. I found just unplugging and plugging back in the relays a couple of times would cure it. Corrosion on the contacts I think.
Chris400
60hp tracker motor. Mercury
roscoe
Poor connection from relay to pump motor.
broken wires between relay and pump motor, or inside pump motor housing
Poor connection of main power source to the relay
25 year old wires can break
Chris400
Does anyone have the wiring schematic for the electrical system for the lift..1995 tracker pro 18 with a 60hp mercury tracker
Chris400
Is there a way to take the wires out of the pump motor housing to check them at the connections in it
