Fl_Richard
Thread starter- Joined
- Jan 21, 2005
- 1,428
I have a 1995 150 Ocean runner with the OIS system. My issue is not with the running of the engine, it's the starting. The starter sometimes makes a screeching noise as it's cranking. The starter/Bendix are two separate parts and to get to the Bendix I need to remove the flywheel cover. I've removed the timing wheel bolt but the brass sleeve is somewhat frozen to the crank shaft.
As the Timing wheel is plastic I really cant pull too hard.. What do i do to remove it? There seems to be nothing to pry against.
Many thanks all!
Richard
Many thanks all!
Richard
